could not open connection to the host on port 23 connect failed for Veralite
I am having problems with my veralite. The firmware appears corrupted.
I have a Vera 3 which ran into the same problems, but I was able to telnet in and it runs perfectly afterward.
when I telnet into the veralite unit, I get the message “could not open connection to the host on port 23 connect failed”.
I set up my computer with 192.168.81.2, and gateway of 192.168.81.1.
I can access the webpage via 192.168.81.1, but not via telnet.
I can ping veralite however.
Any suggestions?
Thanks!
Instead of telnet, you need to ssh into the VeraLite. Telnet is not enabled hence, the connection refused message.
Thank you for your reply, but unfortunately I don’t know this method.
Can you explain it?
If you are on a windows pc, you will need to use putty. If you are on a mac, you can open up a terminal and type in “ssh root@192.168.81.1”. Putty would be similar for windows. You say you can access the webpage? What does the webpage provide you?
  • Garrett
I have a Windows 7 and an XP machine.
What exactly do I do?
Pardon my lack of expertise in this area.
Putty is a windows program. You can download it at www.putty.org
John
Thank you, I’m at the login, and it asks now for a password, but I don’t seem to have this in my documentation, or on the Veralite.
Any ideas?
Have a look at http://forum.micasaverde.com/index.php/topic,7741.msg63317.html#msg63317
Yet a step closer!
I have the backup downloaded, and it is a .tgz file, but I can’t seem to extract files.
I’m clearly doing something wrong.
On windows it is going to be slightly trickier as the .tgz format is a tarred gzip file (widely used on unix). I may be wrong (not a big windows user myself) but Winzip may be able to handle the extract? Or something like Winrar?
Winzip did open it, and the password contained doesn’t work…
I also have problems seeing the backups stored at mios.com.
Is there some other way to see them?
PW finally worked, but there was a zwave appliance controller that I see still exists, and also, the firmware and new name I gave the veralite is still present.
I guess it didn’t properly reset.
Do you press the reset button on the veralite just once?
I believe it needs to be pressed twice in quick succession. It’s been mentioned on the forums before, but I’ve not had a need to perform it so far
You need to reset the Z-Wave network in order to get rid of the devices.
Thank you, that did it!
