im looking but I dont find much on the Costco Insteon kit with the 2245-22 hub. any pointers? will it work?
a little late but, no. the hub won’t work with the vera plus or any vera, you need either a serial or usb plm device even though the insteon hub contains a plm inside of it, not sure if anyone has accessed it directly for a repurposing of it like this (to speak with the vera plus) Walmart liquidated a ton of Insteon over the last year for dirt cheap, lot of hubs floating around
