Here is my situation:
- replaced rotary dimmer and single pole, (two switch system) going to kitchen fixture
- Cooper Aspire 9534 Master replaced rotary dimmer, Cooper Aspire 9542 slave replaced single pole on other side of kitchen
- Four bulbs - LED - each 60W output, each 11W draw
- On/off operation is successful
- Dimming, brightening, remember settings, 10 second off delay all work well - no issues
- When turned off and after some period of time (minutes), 3 of the bulbs turn back on (not always the same 3) at a very low light level. They turn off at some point and back on again. Haven’t sat, watched and timed, but probably not important.
- Green LED on each switch is on all the time.
- Amber LED on 9542 slave is on all the time.
- Amber LED on 9534 master is on only when the switch is turned on.
- Amber/green LEDs do not change when the bulbs turn on by themselves.
- The bulbs do not flicker at any time.
I have read the information on many other sites and looked for a similar situation, but could find none. According to the manual, the required minimum lamp wattage for the two switch combination is 100W.
I would appreciate any advice that can be shared.
Cheers!
