In the market for a Z-Wave controller and after discovering a competing product (Indigo, FWIW) can’t distinguish certain functions of these switches (and judging from the response of its forum moderator that it’s just “stupid,” I don’t think there will be any updates to incorporate these functions), I’m looking at the Vera to determine if it can:
The Cooper Wiring Devices Aspire RF9540-N and RF9542-Z use a vertical column of blue LEDs to indicate the current brightness level “setting” and is always lit regardless of whether the switch is in an “on” or “off” state, allowing the “preset” brightness to be adjusted even when the switch is off. There is a separate amber LED to indicate the actual on/off state of the switch.
So to my question: Can the Vera recognize (and thereby program) the distinct differences of “on,”, “off,” and “brightness level?” The competitor’s product always assumes the “brightness” level also corresponds to it’s on/off state, meaning if the switch is “off” then it assumes (incorrectly for these switches) that the brightness level/setting is always “0”.
Since the remote switch settings (On/Off/Brightness Level) are completely independent from the intended master (and other remote switches for a 3+ way setup), I must be able to synchronize all the settings with all the “associated” switches: if a remote’s brightness level is adjusted, regardless of whether light circuit is actually on or not, I must be able to match all the other switches’ brightness level “setting” to the source switch without changing the current on/off state. Since the competing product assumes that all dimmer commands are basically a “brightness level” event, it maps a brightness level of “0” to “off”, and any other brightness level to “on,” preventing me from independently querying or setting the brightness level separate from the on/off state; it will always assume a “brightness level” event other than the lowest setting is also an “on” event resulting in turning the switch on even if you don’t want that to happen.
Can I operate these 9540/9542 switches correctly with the Vera?
