can someone direct me to the best way of visually controlling various temp sensors that I can use to trigger some solenoids/power switches to COOL rather than heat.
EG: if temp >19 deg then turn on switch
I know I could use PLEG but I was wondering if someone has written a plugin that is a cooling thermostat rather than a heating thermoatat
I need to be able to create at least 20 virtual devices
You can just use scenes and triggers.
On ui7, make a scene triggered by your thermostat/temp sensor at temps above 19. In the scene action choose the solenoid device and set it to on.
Lather/rinse/repeat.
You can make off scenes once the temp goes below 0 to keep from burning out your ACs.
For ui5 you need to use the CurrentTemperature in a trigger and then add a scene with the device on.
You can take help of a professional technician.
