Converting RF remote to Zwave
I am trying to find out if there is a way to convert my screen projectors RF remote to Zwave. I am thinking of some way to open close 3 circuits on the board (Up/Down/Close) using zwave codes.
This is what the board looks like:
(3 buttons where when open or closed something happens)
Front picture of the board
You can not convert it to zwave but you can probably use a global cache relay unit to trigger the contacts.
  • Garrett
What does it look like? I have the WF2IP from that company is that what you are talking about? It’s for IR don’t think it does RF.
http://www.globalcache.com/products/itach/ip2ccspecs/
http://www.globalcache.com/products/itach/wf2ccspecs/
  • Garrett
I see, well at that price might as well get a zwave motor controller :slight_smile:
The global cache WIFI iTach Relays are much more robust than a Z-Wave controller.
More range … faster … and integrate nicely with Vera via the GC-100 driver.
Email me if you want a GC-100 patch for properly displaying the Relay status.
Use a z-wave to dry contact motor module. (12VDC supply required)
Includes directly into the z-wave network and shows as a a shade motor in the Vera UI.
Otherwise same, solder the up/stop/down outputs to the transmitter or to any motor dry contact input, without forgetting the common.
info@zwavemotors.com
This is what the main controller looks like. What z-wave module would I connect to it?
easiest is to replace your AC receiver by a Z-WAve motor controller, ~$80-90.
Where can this be purchased?
contact info@zwavemotors.com
