After reading the threads, and downloading the mios plugins (smartphone interface), still no luck.
What am I missing?
I’m a new user, and so far not a big fan.
Tstat issues
Undefined scenes that can’t be deleted
Factory reset the unit and re enrolled devices twice
Iphone doesn’t work
2 days later I’m frustrated beyond belief.
Can someone please point me in the right direction
What version of the UI are you using? I was not able to use the Smartphone plugin with 1.0.979. I’m now using 1.1.228. Not crazy about the UI3, but the plugin does work.
I’m using 1.0.979 and the smartphone plugin in “works” on the ipod touch. I quote “works” because it wasn’t designed well. Maybe its a limitation of Safari, but its just a web app so every time you click on a command the page reloads. This means you have to hit ‘back’ several times to get back to the dashboard or else keep going back to a saved bookmark. Not horrible I suppose, but its not a good ‘app’.
I couldn’t get the plugin to install with 1.0.979. I upgraded to 1.0.988 it installed finally and “works”. How musch longer will we have to wait for square connect? Please be soon…
