I use Pool Control Plugin with an Autelis to control my Jandy Pool Equipment Controller.
I have scenes to perform certain actions. I’m working on putting these scenes into Alexa using Alexa Routines.
One scene (the first one I’m trying to set up in Alexa) turns on the spa by setting pump speed, turning the JVA’s (Jandy Valve Actuator) to redirect water flow to the spa jets and spa return and then turning on the Spa Heater to a set temperature. This scene works with an Alexa Routine to turn on the spa when I say, “Alexa, turn on the spa”. I have the routine set to turn the Spa On scene “on” when I say this.
Turning the spa off is another thing altogether. I have an opposing scene in Vera to reverse the above things. The scene works fine in Vera as well as using the Macros built into the Pool Control Plugin. I’ve tried setting up the Alexa Routine for when I say, “Alexa, turn off the spa” to no avail. I’ve tried both having that phrase turn the Spa Off scene to both “on” and “off” in the Alexa Routine editor.
I haven’t tried any other pool scenes such as turning the pool heat on or off or any of the party scenes I have set up that set the mood about the pool based on the type of pool activity planned but I suspect the result will be the same for turning it “off”.
Any assistance would be awesome!
Thanks!
