Sorry for my delayed response. I’ve got a couple of home projects going. As you may know the Byron SX is actually a chime device. The RFXtrx plugin for Vera does not yet handle chime devices. I’ll attempt to add these devices, and a way to convert an auto-created device to a extractor fan in the next plugin version.
Are you able to control the LUXAir fan with RFXmngr using the Byron commands?
It is clear that the fan has the some protocol as a Byron SX chime if this is possible and it is useful to spend time to add this device. But only if the original Byron SX can be used too.
For the best answer to this question you would probably need to ask the developer of the RFXtrx transceiver (b_weijenberg). Of course the RFXtrx works, it’s just that the transmit signal strength cannot be varied.
