This was one of my first ‘newbe’ projects:
;D
At home we have a fan for exhaust ventilation.
It’s used for the kitchen and two toilets.
As standard the fan always runs at low speed.
In the kitchen, there is a switch for the middle and high speed.
Now I want to stop the fan at night when we are going te sleep.
My wife has a difficulty getting in to sleep with that sound
And I think it’s silly to run the fan 24 hours a day.
The fan is a ‘JE-Stork CML 14/3’ box fan.
It is located on the attic and has a so called ‘Perilex’ plug.
It uses 19 watt at low speed, 40 watt at medium speed, and 80 watt at high speed.
I have build a Fibaro Relay Insert 2 * 1.5 KW in the fan
The fan is now active on low speed from 07:00 to 22:30 hour.
This through the scheduled scene in my Vera Lite.
To switch the fan to high speed we can activate the second fibaro switch in Vera.
Or in the kitchen by putting the switch to position 2 or 3.
I have made a photo, see attachement.
The original brown en blue wires are also connected to the FGS-221.
I put the black wire from the switch in the kitchen in S2.
I have made a connection from O1 to L3 (module from fan). This is for Low speed
And I have made a connection from O2 to L1 (module from fan) This is for High speed
In the future I also want to put the fan on high speed when someone is using the toilet by putting a fibaro mudule in the light switch.
