I worded directly with global cache and got these codes and offsets to work…works great with my itach wifi to IR and my erod. hope this helps others.
jimmy
im responding to your post about erod. a few months ago when i had the issue i went straight to itach for support…and together me and their tech got hte correct IR codes with the correct offset.
im posting here in this PM for you and will also add to the thread…but htis should do it for you.
Mike
I relearned them all and set the offsets till I got them
You?ve been a huge help?(and you taught me something…thnx)
New codes as follows for everyone:
Close: sendir,1:1,1,37878,3,3,48,16,48,16,16,48,48,16,16,48,16,48,48,16,16,48,16,48,16,48,16,48,16,1324,48,16,48,16,16,48,48,16,16,48,16,48,48,16,16,48,16,48,16,48,16,48,16,3367,48,16,48,16,16,48,48,16,16,48,16,48,48,16,16,48,16,48,16,48,16,48,16,1324,48,16,48,16,16,48,48,16,16,48,16,48,48,16,16,48,16,48,16,48,16,48,16,3367,48,16,48,16,16,48,48,16,16,48,16,48,48,16,16,48,16,48,16,48,16,48,16,3787
Open:
sendir,1:1,1,37650,3,3,48,16,48,16,16,47,48,16,16,47,16,47,16,47,48,16,16,47,16,47,16,47,16,1316,48,16,48,16,16,47,48,16,16,47,16,47,16,48,48,16,16,47,16,48,16,48,16,3765
Stop: sendir,1:1,1,36337,3,3,8,53,16,46,16,3230,48,15,48,15,16,46,48,15,16,46,16,46,16,46,16,46,48,15,16,46,16,46,16,1270,48,15,48,15,16,46,48,15,16,46,16,46,16,46,16,46,48,15,16,46,16,46,16,3230,48,15,48,15,16,46,48,15,16,46,16,46,16,46,16,46,48,15,16,46,16,46,16,1270,48,15,48,15,16,46,16,46,16,46,16,46,16,46,16,46,16,46,16,46,16,46,16,3633
