I have an Aeotec Water and Flood Sensor. It shows up just fine in the Vera. However, it seems there is no Control4 driver for this type of device. I have tried the Humidity and Security Sensor drivers and neither seem to be the right ones. The Security Sensor Driver binds to the device in Vera, but the only variable available for programming is battery which doesn’t help much. Any thoughts?
EDIT: Figured it out. Install the Security Sensor driver and then install the generic Water Sensor Driver. Bind the Security Sensor > Security Sensor to the Water Sensor in Connections.
