I just tried this too and got the same error. It appears that this was written in 2012 for a Vera 2, which at the time would have been running ?UI4? so may not work with UI5 or UI7.
If this did work, I would use it all the time.[/quote]
…at this point, how would it know? Possibly a compatibility issue with the XBMC version, which has changed since 2012.
I wish I could be of assistance, as I would love to have this plug-in working on my android TV box as well, but I am extremely challenged in the programming department
This may also help. I enabled debug and logged the error after doing the same modification to the python version that @fusion600 performed, and to no surprise, the same thing happened to me.
Here are the log files of the error that clearly points to specific lines in the ‘main.py’ file.
I have also posted on the Kodi forums to see if anyone over there can help. @nickr is making an attempt to help out over there. We’ll see what comes of it.
I remember seeing something about this add-on. I’m going to try it out and see if I am successful making any of it work. It seems that @cw-kid has already jumped thru a few of the hoops and has made a bit of progress. Let’s continue this discussion on the other post so it is all in one spot.
