I’m doing some stress testing with GCal3 on AltUI and openluup - no vera.
Using the latest releases but unregistered AltUI.
When I set a notification for the device - the Control Panel no longer displays.
This could easily be operator error as I’m new to AltUI and openluup. Or the fact that AltUI is not registered (although I would expect some sort of error). Or maybe I have a bug in GCal3. or … ?
What can I do to assist in resolving ?
Here are the repeatable steps.
- Fresh install of GCal3 from Alt App Store - verified working with test calendar
- Open ControlPanel displays normally, Create Notification for “Event start or finish”
- In Scene panel - just click submit. Note that I cannot select a user as nothing displays for that button.
- Return to devices tab, Open Control Panel – nothing displays, no tabs no nothing.
This is the relevant portion of the openluup log file
2018-10-03 19:15:16.891 openLuup.http:: GET /data_request?id=scene&action=create&json=%7B%22timers%22%3A%5B%5D%2C%22triggers%22%3A%5B%7B%22name%22%3A%22Notification%20from%20Google%20Calendar%203%22%2C%22enabled%22%3A1%2C%22template%22%3A%223%22%2C%22device%22%3A18%2C%22arguments%22%3A%5B%7B%22id%22%3A1%7D%5D%2C%22lua%22%3A%22%22%7D%5D%2C%22groups%22%3A%5B%7B%22delay%22%3A0%2C%22actions%22%3A%5B%5D%7D%5D%2C%22name%22%3A%22Notification%20from%20Google%20Calendar%203%22%2C%22lua%22%3A%22%22%2C%22room%22%3A0%2C%22notification_only%22%3A18%2C%22modeStatus%22%3A%220%22%2C%22paused%22%3A0%2C%22triggers_operator%22%3A%22OR%22%7D HTTP/1.1 tcp{client}: 0x55e370306768
2018-10-03 19:15:16.892 openLuup.http:: request completed (2 bytes, 1 chunks, 1 ms) tcp{client}: 0x55e370306768
2018-10-03 19:15:17.397 openLuup.http:: request completed (358 bytes, 1 chunks, 19050 ms) tcp{client}: 0x55e37040d578
2018-10-03 19:15:17.402 openLuup.http:: GET /data_request?id=user_data&output_format=json&DataVersion=593381258&_=1538594093598 HTTP/1.1 tcp{client}: 0x55e37040d578
2018-10-03 19:15:17.408 openLuup.http:: request completed (64593 bytes, 5 chunks, 5 ms) tcp{client}: 0x55e37040d578
2018-10-03 19:15:19.382 openLuup.http:: GET /data_request?id=lu_status2&output_format=json&DataVersion=593381634&Timeout=60&MinimumDelay=1500&_=1538594093599 HTTP/1.1 tcp{client}: 0x55e37040d578
