Is it possible to control garage door opener using the Global Cache GC100 Relay ports? Can Just wire directly from the Global Cache to the Garage Door Opener button? Or do i need other parts/component?
[quote=“bigmonkey70, post:1, topic:175719”]Is it possible to control garage door opener using the Global Cache GC100 Relay ports? Can Just wire directly from the Global Cache to the Garage Door Opener button? Or do i need other parts/component?
Thanks[/quote]
That should work fine. Hook the relay ports up to the opener button terminals in parallel with the existing opener.
Keep in mind that you won’t know open/close state of the door without door sensors.
If you add the Door Sensor you should then use the Garage Door Plugin
Also you should install my GC100 Patch … Otherwise the relays do not show status on Vera Properly.
Does the Garage Door Plug in work with Vera 2?
It should … I developed on UI4 and no changes on UI5.
When I tried to install from the app store, it gave me an error
installation failed, reason: to install plugin.
I have attached the file you will need to upload to Vera.
You can create a device instance on UI4 following the instructions from the first post of:
http://forum.micasaverde.com/index.php/topic,5106.0.html
However you do not need to edit this file … (This was only needed with the original version) You will customize as described at:
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
