What am i looking for in the logs?
Something like this?
06 03/14/18 21:40:50.131 Device_Variable::m_szValue_set device: 227 service: urn:upnp-org:serviceId:altui1 variable: Version was: v2.16 now: v2.16 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x73db2520>
06 03/14/18 21:40:50.673 Device_Variable::m_szValue_set device: 227 service: urn:upnp-org:serviceId:altui1 variable: DataStorageProviders was: { "emoncms": { "url": "", "callback": "sendValueToStorage_emoncms", "parameters": [ { "default": 1, "type": "number", "key": "nodeid", "label": "Node ID" }, { "type": "number", "key": "feedid", "label": "Feed ID" }, { "type": "text", "key": "inputkey", "label": "Input Key name" }, { "type": "text", "key": "readwritekey", "label": "Read/Write API Key" }, { "type": "url", "key": "graphicurl", "label": "Graphic Url", "ifheight": 460, "default": "http://emoncms.org/vis/realtime?feedid={1}&embed=1&apikey={3}" } ] }, "thingspeak": { "url": "", "callback": "sendValueToStorage_thingspeak", "parameters": [ { "type": "number", "key": "channelid", "label": "Channel ID" }, { "type": "text", "key": "readkey", "label": "Read API Key" }, { "type": "text", "key": "writekey", "label": "Write API Key" }, { "default": 1, "type": "number", "key": "fieldnum", "label": "Field Number" }, { "default": "//api.thingspeak.com/channels/{0}/charts/{3}?key={1}&width=450&height=260&results=60&dynamic=true", "type": "url", "key": "graphicurl", "label": "Graphic Url" } ] }, "IFTTT": { "url": "", "callback": "sendValueToStorage_ifttt", "parameters": [ { "type": "text", "key": "webhookkey", "label": "Web Hook Key" }, { "default": "vera_data_published", "type": "text", "key": "eventname", "label": "Hook Event Name" } ] } } now: { "emoncms": { "url": "", "callback": "sendValueToStorage_emoncms", "parameters": [ { "key": "nodeid", "type": "number", "default": 1, "label": "Node ID" }, { "type": "number", "key": "feedid", "label": "Feed ID" }, { "type": "text", "key": "inputkey", "label": "Input Key name" }, { "type": "text", "key": "readwritekey", "label": "Read/Write API Key" }, { "type": "url", "key": "graphicurl", "label": "Graphic Url", "ifheight": 460, "default": "http://emoncms.org/vis/realtime?feedid={1}&embed=1&apikey={3}" } ] }, "IFTTT": { "url": "", "callback": "sendValueToStorage_ifttt", "parameters": [ { "type": "text", "key": "webhookkey", "label": "Web Hook Key" }, { "key": "eventname", "type": "text", "default": "vera_data_published", "label": "Hook Event Name" } ] }, "thingspeak": { "url": "", "callback": "sendValueToStorage_thingspeak", "parameters": [ { "type": "number", "key": "channelid", "label": "Channel ID" }, { "type": "text", "key": "readkey", "label": "Read API Key" }, { "type": "text", "key": "writekey", "label": "Write API Key" }, { "default": 1, "type": "number", "key": "fieldnum", "label": "Field Number" }, { "default": "//api.thingspeak.com/channels/{0}/charts/{3}?key={1}&width=450&height=260&results=60&dynamic=true", "type": "url", "key": "graphicurl", "label": "Graphic Url" } ] } } #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73db2520>
06 03/14/18 21:40:50.715 Device_Variable::m_szValue_set device: 227 service: urn:upnp-org:serviceId:altui1 variable: DataStorageProviders was: { "emoncms": { "url": "", "callback": "sendValueToStorage_emoncms", "parameters": [ { "key": "nodeid", "type": "number", "default": 1, "label": "Node ID" }, { "type": "number", "key": "feedid", "label": "Feed ID" }, { "type": "text", "key": "inputkey", "label": "Input Key name" }, { "type": "text", "key": "readwritekey", "label": "Read/Write API Key" }, { "type": "url", "key": "graphicurl", "label": "Graphic Url", "ifheight": 460, "default": "http://emoncms.org/vis/realtime?feedid={1}&embed=1&apikey={3}" } ] }, "IFTTT": { "url": "", "callback": "sendValueToStorage_ifttt", "parameters": [ { "type": "text", "key": "webhookkey", "label": "Web Hook Key" }, { "key": "eventname", "type": "text", "default": "vera_data_published", "label": "Hook Event Name" } ] }, "thingspeak": { "url": "", "callback": "sendValueToStorage_thingspeak", "parameters": [ { "type": "number", "key": "channelid", "label": "Channel ID" }, { "type": "text", "key": "readkey", "label": "Read API Key" }, { "type": "text", "key": "writekey", "label": "Write API Key" }, { "default": 1, "type": "number", "key": "fieldnum", "label": "Field Number" }, { "default": "//api.thingspeak.com/channels/{0}/charts/{3}?key={1}&width=450&height=260&results=60&dynamic=true", "type": "url", "key": "graphicurl", "label": "Graphic Url" } ] } } now: { "emoncms": { "url": "", "callback": "sendValueToStorage_emoncms", "parameters": [ { "default": 1, "type": "number", "key": "nodeid", "label": "Node ID" }, { "type": "number", "key": "feedid", "label": "Feed ID" }, { "type": "text", "key": "inputkey", "label": "Input Key name" }, { "type": "text", "key": "readwritekey", "label": "Read/Write API Key" }, { "type": "url", "key": "graphicurl", "label": "Graphic Url", "ifheight": 460, "default": "http://emoncms.org/vis/realtime?feedid={1}&embed=1&apikey={3}" } ] }, "IFTTT": { "url": "", "callback": "sendValueToStorage_ifttt", "parameters": [ { "type": "text", "key": "webhookkey", "label": "Web Hook Key" }, { "key": "eventname", "type": "text", "default": "vera_data_published", "label": "Hook Event Name" } ] }, "thingspeak": { "url": "", "callback": "sendValueToStorage_thingspeak", "parameters": [ { "type": "number", "key": "channelid", "label": "Channel ID" }, { "type": "text", "key": "readkey", "label": "Read API Key" }, { "type": "text", "key": "writekey", "label": "Write API Key" }, { "default": 1, "type": "number", "key": "fieldnum", "label": "Field Number" }, { "default": "//api.thingspeak.com/channels/{0}/charts/{3}?key={1}&width=450&height=260&results=60&dynamic=true", "type": "url", "key": "graphicurl", "label": "Graphic Url" } ] } } #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73db2520>
06 03/14/18 21:40:50.748 Device_Variable::m_szValue_set device: 227 service: urn:upnp-org:serviceId:altui1 variable: DataStorageProviders was: { "emoncms": { "url": "", "callback": "sendValueToStorage_emoncms", "parameters": [ { "default": 1, "type": "number", "key": "nodeid", "label": "Node ID" }, { "type": "number", "key": "feedid", "label": "Feed ID" }, { "type": "text", "key": "inputkey", "label": "Input Key name" }, { "type": "text", "key": "readwritekey", "label": "Read/Write API Key" }, { "type": "url", "key": "graphicurl", "label": "Graphic Url", "ifheight": 460, "default": "http://emoncms.org/vis/realtime?feedid={1}&embed=1&apikey={3}" } ] }, "IFTTT": { "url": "", "callback": "sendValueToStorage_ifttt", "parameters": [ { "type": "text", "key": "webhookkey", "label": "Web Hook Key" }, { "key": "eventname", "type": "text", "default": "vera_data_published", "label": "Hook Event Name" } ] }, "thingspeak": { "url": "", "callback": "sendValueToStorage_thingspeak", "parameters": [ { "type": "number", "key": "channelid", "label": "Channel ID" }, { "type": "text", "key": "readkey", "label": "Read API Key" }, { "type": "text", "key": "writekey", "label": "Write API Key" }, { "default": 1, "type": "number", "key": "fieldnum", "label": "Field Number" }, { "default": "//api.thingspeak.com/channels/{0}/charts/{3}?key={1}&width=450&height=260&results=60&dynamic=true", "type": "url", "key": "graphicurl", "label": "Graphic Url" } ] } } now: { "emoncms": { "url": "", "callback": "sendValueToStorage_emoncms", "parameters": [ { "default": 1, "type": "number", "key": "nodeid", "label": "Node ID" }, { "type": "number", "key": "feedid", "label": "Feed ID" }, { "type": "text", "key": "inputkey", "label": "Input Key name" }, { "type": "text", "key": "readwritekey", "label": "Read/Write API Key" }, { "type": "url", "key": "graphicurl", "label": "Graphic Url", "ifheight": 460, "default": "http://emoncms.org/vis/realtime?feedid={1}&embed=1&apikey={3}" } ] }, "IFTTT": { "url": "", "callback": "sendValueToStorage_ifttt", "parameters": [ { "type": "text", "key": "webhookkey", "label": "Web Hook Key" }, { "default": "vera_data_published", "type": "text", "key": "eventname", "label": "Hook Event Name" } ] }, "thingspeak": { "url": "", "callback": "sendValueToStorage_thingspeak", "parameters": [ { "type": "number", "key": "channelid", "label": "Channel ID" }, { "type": "text", "key": "readkey", "label": "Read API Key" }, { "type": "text", "key": "writekey", "label": "Write API Key" }, { "default": 1, "type": "number", "key": "fieldnum", "label": "Field Number" }, { "default": "//api.thingspeak.com/channels/{0}/charts/{3}?key={1}&width=450&height=260&results=60&dynamic=true", "type": "url", "key": "graphicurl", "label": "Graphic Url" } ] } } #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73db2520>
06 03/14/18 21:40:50.749 Device_Variable::m_szValue_set device: 227 service: urn:upnp-org:serviceId:altui1 variable: VariablesToSend was: now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x73db2520>
06
