I all of a sudden got a problem with continuous reboots. I have removed unused plugins (I’m not using ERGY) and installed a USB hub and stick and enabled logging to it. Power cycle didn’t help. I have a modest amount of plugins and only one PLEG instance so far.
I would really appreciate some help on this. I can’t tell what’s going wrong from reading the log but hopefully it makes sense to someone else. I’ve pasted the last bit before for the LuaUPNP crash message. I’m happy to post more of the log if needed.
[code]02 01/18/14 19:50:31.103 ZW_Send_Data node 13 NO ROUTE (nil) <0x2b77f680>
04 01/18/14 19:50:31.242 LEAK this:73728 start:6901760 to 0x18bd000 <0x2b37f680>
01 01/18/14 19:50:33.003 Failed to get lock(0x107a84c) Lua: LuaInterface.cpp:1686 last used LuaInterface.cpp:1990 first used LuaInterface.cpp:1990 thread: 0x2d77f680 (>5857) handler 0x424934 bOkToFail 0 LEAK this:221184 start:7122944 to 0x18f3000 <0x2ac4c000>
02 01/18/14 19:50:33.005 Dumping 25 locks <0x2ac4c000>
02 01/18/14 19:50:33.005 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.006 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.007 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.008 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.009 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.010 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.010 OL: (0x107a84c) (>5857) Lua LuaInterface.cpp l:1990 time: DL7:49:32p (61 s) thread: 0x2d77f680 Rel: N Got: Y <0x2ac4c000>
02 01/18/14 19:50:33.011 OL: (0xa9ad9c) (>6216) ThreadedClass …/JobHandler/JobHandler.cpp l:404 time: 7:49:33p (60 s) thread: 0x2ac4c000 Rel: Y Got: Y <0x2ac4c000>
02 01/18/14 19:50:33.021 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.022 OL: (0x107a84c) (>6220) Lua LuaInterface.cpp l:1686 time: 7:49:33p (60 s) thread: 0x2ac4c000 Rel: N Got: N <0x2ac4c000>
02 01/18/14 19:50:33.022 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.022 OL: (0xa9ae0c) (>10254) Variable JobHandler_LuaUPnP.cpp l:6848 time: 1:00:00a (1390071033 s) thread: 0x2f57f680 Rel: Y Got: Y <0x2ac4c000>
02 01/18/14 19:50:33.023 finished check for exceptions <0x2ac4c000>
02 01/18/14 19:50:33.023 OL: (0xd21c6c) (>10305) ThreadedClass …/JobHandler/JobHandler.cpp l:404 time: 1:00:00a (1390071033 s) thread: 0x2b77f680 Rel: Y Got: Y <0x2ac4c000>
01 01/18/14 19:50:33.023 Deadlock problem. going to reload and quit <0x2ac4c000>
03 01/18/14 19:50:33.023 JobHandler_LuaUPnP::Reload: deadlock Critical 1 m_bCriticalOnly 0 dirty data 1 <0x2ac4c000>
02 01/18/14 19:50:33.922 luup_log:7: RFXtrx: Bad starting message; ignore byte 60 LEAK this:200704 start:7323648 to 0x1924000 <0x2f37f680>
06 01/18/14 19:50:33.923 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 v:0xdee098/NONE duplicate:0 <0x2ac4c000>
06 01/18/14 19:50:33.924 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 v:0xdee150/NONE duplicate:0 <0x2ac4c000>
01 01/18/14 19:50:40.358 Main WatchDogRoutine: blocked - terminating 1 LEAK this:-659456 start:6664192 to 0x1883000 <0x2e17f680>
02 01/18/14 19:50:40.359 Dumping 21 locks <0x2e17f680>
02 01/18/14 19:50:40.360 finished check for exceptions <0x2e17f680>
02 01/18/14 19:50:40.360 finished check for exceptions LEAK this:73728 start:6737920 to 0x1895000 <0x2e17f680>
02 01/18/14 19:50:40.381 finished check for exceptions <0x2e17f680>
02 01/18/14 19:50:40.382 finished check for exceptions <0x2e17f680>
02 01/18/14 19:50:40.383 finished check for exceptions <0x2e17f680>
02 01/18/14 19:50:40.384 finished check for exceptions <0x2e17f680>
02 01/18/14 19:50:40.385 finished check for exceptions <0x2e17f680>
02 01/18/14 19:50:40.385 OL: (0x107a84c) (>5857) Lua LuaInterface.cpp l:1990 time: DL7:49:32p (68 s) thread: 0x2d77f680 Rel: N Got: Y <0x2e17f680>
02 01/18/14 19:50:40.385 OL: (0xa9ad9c) (>6216) ThreadedClass …/JobHandler/JobHandler.cpp l:404 time: 7:49:33p (67 s) thread: 0x2ac4c000 Rel: Y Got: Y <0x2e17f680>
02 01/18/14 19:50:40.386 finished check for exceptions <0x2e17f680>
02 01/18/14 19:50:40.386 OL: (0x107a84c) (>6220) Lua LuaInterface.cpp l:1686 time: 7:49:33p (67 s) thread: 0x2ac4c000 Rel: N Got: N <0x2e17f680>
2014-01-18 19:50:40 - LuaUPnP Terminated with Exit Code: 137
2014-01-18 19:50:40 - LuaUPnP crash[/code]
