So i’m trying to get specific values from a xml file but after days of searching I’m none the wiser
This is the source XML
[code]
UPS StatusUPS Status
<h2 class="expandable ">- System Status</h2>
<div class="label-value-group ui-corner-all">
<div class="label-value-pair">
<label>Device Status</label>
<div id="value_DeviceStatus" class="value">On line (Green Mode)</div>
</div>
<label>UPS Load</label>
<div id="value_RealPowerPct" class="value">20.8</div>
<div class="unit">%</div>
</div>
<label>Runtime Remaining</label>
<div id="value_RuntimeRemaining" class="value">49</div>
<div class="unit">Minutes</div>
</div>
</div>
</div>
I first thought LXP and xpatch would be the cleanest way to do it so I stole this code
[code]local socket = require(“socket”)
local ltn12 = require(‘ltn12’)
local https = require(“ssl.https”)
local lom = require’lxp.lom’
local xpath = require’xpath’
function https.get(u)
local response_body = { }
local rBody, code, response_headers, rStatus = https.request{
url = u,
method = “GET”,
verify = “none”,
mode = “client”,
options = “all”,
protocol = “sslv3”,
headers = {
[“Accept”] = “text/html”,
[“Accept-Encoding”] = “sdch”,
sink = ltn12.sink.table(response_body),
return table.concat(response_body), rBody, code, response_headers, rStatus
local xml_tree = lom.parse(https.get((‘https://192.168.148.3:6547/quickstatus’)))
print(xml_tree)
[/code]
The output was blank and this is the furthest I’ve have gotten without any errors :-[
Then I thought regex could solve it but this code won’t work neither probably because of the " symbols
I’m trying to get this
[code]
url = u,
method = “GET”,
verify = “none”,
mode = “client”,
options = “all”,
protocol = “sslv3”,
headers = {
local xml_tree = (https.get((‘https://192.168.148.3:6547/quickstatus’)))
local DeviceStatus = xml_tree: match “
print(DeviceStatus)[/code]
returns a “attempt to call global ‘value_DeviceStatus’ (a nil value)”
The XML file is not that big and i’ve read that regex is faster then LXP. So what is the best approach in my case and what I’m I doing wrong?
My reading material for anyone who’s on the same path:
[url=http://luaxpath.luaforge.net/manual.html]http://luaxpath.luaforge.net/manual.html[/url] LUA XPath
[url=http://forum.micasaverde.com/index.php?topic=12408.15]http://forum.micasaverde.com/index.php?topic=12408.15[/url] user: Hek, wrote a nice script that uses LXP and Xpath
[url=http://forum.micasaverde.com/index.php/topic,15176.0.html]http://forum.micasaverde.com/index.php/topic,15176.0.html[/url] user: mda, wrote a script that uses regex
Belkin WeMo plugin and the weatherparsing script also uses LXP but that script was way to complex for me to understand
