I made some kind of Variable Container that can hold 5 Temperatures from 5 Sensors.
You need to insert Sensor ID, Offset(if you want to see the sensor temp + or - something), Poll Device ID(if you need to poll the device or its parent to update the current temp from the sensor) and Pol Device Period.
To create the new device you need to use Create Device.
The device will get and write the temperatures.
[quote=“bore, post:1, topic:195283”]I made some kind of Variable Container that can hold 5 Temperatures from 5 Sensors.
I hope it will be useful.[/quote]
Bore,
What device or interface allows you to minitor 5 sensors.
