Contact Code and VeraAlert[8]
I extremely new at this and I wasted the last few hours trying to find a code number to satisfy the following:
IMPORTANT: Your phone number cannot be used until you verify it by entering the code number we sent you.
I keep hitting “Resend Code” but I can’t find it in my emails or anywhere! The only number that I find in my initial setup notes is: 30009602-870945. I don’t know if this is the Code.
Also:
I can’t get the following to go away even though I found VeraAlerts[8]
VeraAlerts[8]:Is Not Initialized! Open Profiles Tab
02/11/14: I received help from Dana Focariu of the Vera Smarter Home Control Team who helped me Validate my Vera 3 System! I can now receive both email and SMS Alert Notifications.
So, Veraalerts is a plugin that you (and I) have installed from the “APPS” tab on the Vera web portal page.
The message “VeraAlerts[8]:Is Not Initialized! Open Profiles Tab”
just needs you to click on the veraalerts Plugin and click on the wrench icon, and then go to profiles.
And set up the user profiles you want…
You don’t have to use Veraalerts, it is an alternate (BETTER) system of sending you notifications from your vera.
Thanks Jim
I’ve been going crazy looking for that. I found the Vera Alerts App that I had installed a few days ago but mine doesn’t have a little wrench but I did get into the Profiles Tab and right away figured that I had a lot more reading to do!
Thanks for taking the time to help!! Hopefully all of this will be behind me soon and I’ll get some real Automation going!!
Thanks Again
Jim
