console
I’m using v17.1.18 and it seems the console is not loading. Did not try it with previous versions so cannot compare.
Could you elaborate a little?
[ul][li]You are using the link from the openLuup device panel, and nothing happens?[/li]
[li]Have you tried a different browser?[/li][/ul]
The console is pure CSS/HTML, so should work anywhere.
Indeed I use the link :3480/console. Tried with explorer, firefox and chrome but none is responding
Checked the logfile and found this error
openLuup.context_switch:: ERROR: ./openLuup/console.lua:195: bad argument #4 to ‘format’ (string expected, got nil)
Can you replace the openLuup/console.lua with this one and reload?
it’s working fine now, thanks. Useful information also http://forum.micasaverde.com/Smileys/classic/smiley.gif
