Hello
I need to pair two Vera networks but I don’t have Internet in my place!!! Please advice what to do!!!
I have read manual about that there was told that Vaeras must be in the same network! If this is right please tell me how I can do that.
I have two UI4 Veras.
Thanks.
These things don’t really like to be running without the internet (to set the clock) and if you don’t plan on giving them an internet connection in the future, then you should think about trying to setup an NTP (Network Time Protocol) solution to set the clock!
Hopefully you have a laptop or something to connect to your Vera’s, and have some knowledge of how to configure IP addresses etc?!
Primarily, you need to start of by making one of them acting as a router/gateway from within Setup and Net and WiFi page, and with Wifi on!
On the second Vera (in the same Net & WiFi Page), you need to set it up in WiFi client mode, and configure it to connect to your first Vera’s WiFi.
Presuming you managed to get them both networked, then you need follow the bridging process here:
Thanks.I’ll try!!!
[quote=“strangely, post:2, topic:171692”]These things don’t really like to be running without the internet (to set the clock) and if you don’t plan on giving them an internet connection in the future, then you should think about trying to setup an NTP (Network Time Protocol) solution to set the clock!
http://wiki.micasaverde.com/index.php/Bridged_Mios_Engines[/quote]
I am now trying to connect from one Vera to other from Advanced>Net & WiFi > Through another gateway on my network. MiOS is a switch or Through a wi-fi access point. MiOS is a bridge there in wireless section I’m searching for wifi network.After writing password I’m pushing pick and nothing happens.
please advice me what to do?
So on the second Vera you need to select “Through a wi-fi access point. MiOS is a bridge”
I remember it being a bit tricky to get the settings to stick, but I think you may have to save also!
[quote=“strangely, post:5, topic:171692”]So on the second Vera you need to select “Through a wi-fi access point. MiOS is a bridge”
I remember it being a bit tricky to get the settings to stick, but I think you may have to save also![/quote]
Finally I have paired two Veras > One as router second bridged!
But unfortunately in Add control over another UPnP I can’t see non of my devices.I can’t see paired Vera too.
At least I can’t see anything regarding paired Vera.
Please help me.Advice me what to do to do to lengthen distance between my devices.
Thanks.
Is this on the main vera or the vera that is bridged? Only the main vera (meaning the vera that you used to find and bridge the second vera) can see all of the devices. The bridged vera (second unit) can only see it’s devices and not that of the main vera.
- Garrett
[quote=“garrettwp, post:7, topic:171692”]Is this on the main vera or the vera that is bridged? Only the main vera (meaning the vera that you used to find and bridge the second vera) can see all of the devices. The bridged vera (second unit) can only see it’s devices and not that of the main vera.
- Garrett[/quote]
I can’t see any devices on main Vera!
I can see devices of main Vera from bridged one. But unfortunately I can’t see incoming signal from that devices. For example if manually one socket of main Vera is turned on in bridged Vera it didn’t not shows.
How can I fix that because I need to write themes from one vera’s paired device to another?
Let me get this right. You can see the main Vera devices on the bridged unit? So the one unit is showing both Vera devices?
- Garrett
Yes it is bridged one.
But I can’t see any change in bridged Vera dashboard if I manually turn on/off device from main one.
-Alex
