Ok i have Managed to set sonoff mini to DIY mode and connected it to vera locally using info here
first connect to ewelink app and update firmware to 3.60 then remove device from ewelink app.
Using @therealdb virtual http device pluging you can control them using curl curl://-d '{"deviceid": "1000a43b57","data": {"switch": "on"}}' -H 'Content-Type: application/json' -X POST 'http://192.168.1.170:8081/zeroconf/switch' or off
another way to control these it to create virtual switches using Switchboard Plugin and then setting up a get request for each switch action in Reactor. Here is an example of the GET request to use. http://192.168.1.210/control?cmd=gpio,12,1
