I have an old Visonic Powermax alarm panel: http://www.visonic.com/Data/Uploads/PowerMax_English_User_Guide_DE5450U7.pdf
I want to connect this panel to my Vera 3. On the back of this unit, it has a 4 pin connector (please see attached photo). I believe just like the new Powermax panels, only 3 pins are used: TXD, GND, and RXD. And looking at the photo, indeed only 3 pins are connected to the board.
I bought this USB to TTL serial console cable from ebay: http://www.ebay.com/itm/121191683482
Thing is, I do not know the pin out of the Powermax panel to connect the above cable. Anyone know it? I also just noticed that it says “RS-232” on the panel…and the cable I bought is TTL which is 3.3volts. Will this work instead of purchasing the Powermax RS232 module, which is much more expensive and very hard to find?
Thanks!
