I recently upgraded from Vera lite to Vera Plus. After experiencing many “can’t detect device” errors, tech support had me do a clean install. I have re-installed all the devices including apps and Vera Alerts. Now when I select “configure Notifications” in Vera Alerts, the area is empty even though I have setup notification alerts for several door and motion detectors. I have applied several of the troubleshooting steps discussed in other threads with negative results. I am running Vera version 1.7.2935 (I was told by tech support not to upgrade to the latest firmware), my Vera Alerts app is running version 7.23. I can send myself a test message and it works fine. Greatly appreciate any advice ???.
Are they enabled in Settings ?
Yes, I have all notification enabled (checked) for now.
Email me a copy for the “Vera Alerts Report”
Thank you for responding, Vera Alert report is attached as a PDF file. Thank you
From the reports, I can see you have not assigned a user to receive the notification for your devices notifications or scene notifications.
- In Vera Alerts when a Device is notified or a scene is notified it checks which user is the recipient.
- It then uses the User to Profile association to determine which profiles to send messages to.
Without users, nothing is sent.
Well Duh :-[ I It showed the user checked but was grayed out, did not realize that I had to check it again to make it green. My apologies for being such a dummy.
