Configuration settings for Z-Wave devices
The Vera hub had a way of viewing/setting parameters available for some devices. I haven’t seen a way to do that for the EZLO hubs. Is it there somewhere?
Hello @tinman
The Z-Wave parameters are available in the MiOS app under your device settings: More → Device → ( > ) → Z-Wave Settings, or on ezlogic.mios.com under Settings → Devices → [your device’s settings].
This page seems to describe it quite well (for MiOS App):
https://support.getvera.com/hc/en-us/articles/360015079980-How-to-customize-your-Z-Wave-device-parameters-guide-for-the-advanced-users
I noticed that the web frontend seems to be missing functions again.
The MiOS app also has so-called default parameters that are created when the devices are integrated. These can be easily set using a slider, check box or option box.
Vera also had the option to read parameters (monitor parameters).
