I’m trying to figure out how to use Lua to trigger/prevent scenes. I’d appreciate if someone can give me a hand with this.
I set up this script attached to a scene, but it seems to trigger no matter what. Any ideas?
local allow = true
local status = luup.variable_get(“urn:schemas-micasaverde-com:device:ElkAlarmPartition:1”, “DetailedArmMode”, 6)
return ((status == “Armed”) == allow)
What I’m trying to do is prevent the scene from happening if I am at home, even if the system is armed StayInstant, but work if I’m out and the system is armed away. Thanks!
Success! It seems that it works. (knock on wood… I only tested once)
local allow = true
local status = luup.variable_get(“urn:micasaverde-com:serviceId:AlarmPartition2”,“ArmMode”,6)
did not work for my application because apparently StayInstant is considered Armed, just as when it’s armed in away mode. However, using this worked:
local allow = true
local status = luup.variable_get(“urn:micasaverde-com:serviceId:AlarmPartition2”,“DetailedArmMode”,6)
Thanks so much for your help!
