Hello,
i’m trying to make a conditional scene to retract my sunscreen when the wind is blowing to hard.
I created a scene with the windsensor as a triger and that wordks perfect.
Only now the vera want’s to close the sunscreen all the time when the wind is above the set value.
even when the sunscreen is alreadu retracted (statu=0). i’m using a fibaro micro module to control the windscreen.
so i want to make the scene conditional, that means if the fibaro controiller (device#17) has status “0” i don’t want the scene to run.
i created a code for this based on information i found, but when i test the luup code it fails.
Can anyone help create the right code wich i can use, any help will be highly appreciated.
this is the code i got sofar
local lul_tmp = luup.variable_get("urn:schemas-micasaverde-com:device:WindowCovering:1", "Status", 17)
if (lul_tmp == "0") then
return false
else
return true
check your service ID
“urn:schemas-micasaverde-com:device:WindowCovering:11”
hover over the Status variable and it will return the right service ID as attached
i changed the code to
local lul_tmp = luup.variable_get("urn:upnp-org:serviceId:SwitchPower:1", "Status", 17)
return false
else
return true
when i test the code it says message sent.
but it looks like it has no effect on the scene
are the last three lines ok ?
The script will cancel the scene if lul_tmp == “0”
That is what you want, right?
I don’t think your Service ID is right, still. Verify the way I told you by hovering over Status on the device. It probably says:
urn:upnp-org:serviceId:SwitchPower1
No colon, yeah?
status is a number 0 or 1
If (lul_tmp == 0) then
you are right again.
this is the right one
local lul_tmp = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 17)
return false
else
return true
at first it didn’t work properly, because i had to reload to get working after status change.
i added the luup code to the scene.
now i removed the code from the scene and added it to the trigger.
now it’s working perfectly !!
Thank you very much for your support and guiding me in the right way.
Regards, Sjoerd
happy to help, we were all there once.
One thing to keep in mind is when you use the “Test Lua Code” bit Vera is’t really debugging like you may be accustomed.
