Richard, I think that something weird happen or I am missing something. I am attaching my status. As you can see, marked in yellow, the condition “music_on_bedroom_working_mornings” was satisfied in an hour that is out of schedule. I mark all the triggers, schedule and properties attached to that condition, it was not supposed to get true at 19.35 and it did. I didn’t change anything in that. The last change I made before that was bedroom_late_when_sleeping, but I am pretty sure they are not conflictuating each other, and this last one is working as expected. Hope you can help.
The mystery is solved, Your question was how could the following condition trigger in the evening:
Music_on_bedroom_workirg_mornings
Which is defined as:
(working_day_morning; bedroom_on < 2:45:00) and (bedroom_lamp_loadlevel == 100)
The answer is because apparently the Switch sets the load level status BEFORE it sets the state. So the previous ON was in the morning, within the 2:45:00 of the wakeup time ?
The sequence expressions did NOT care that the bedroom_on was from earlier in the day. So all day an into the evening this condition was true. Bedroom_lamp_loadlevel was detected first ? so the condition was true.
This is supported by the fact that the various times were:
load level: 19:35:01.818
Condition: 19:35:01.818
State: 19:35.02.0277
Only ? second difference.
To fix this change the condition to:
(working_day_morning; bedroom_lamp_loadlevel < 2:45:00) and (bedroom_lamp_loadlevel == 100)
i.e. use only 1 variable from the switch ? Since using two has a small race condition.
Thank you Richard, that 1/2 second was it, it is know fixed. And don’t worry about the alert, on the contrary, thank you for worrying so much for your users.
