Figured out why it didn’t “install.sh” on my default Ubuntu 16.04 LTS box
xxxxx@xxxxxx:/xxxx/xxxx/ConciergeServer$ cat install.sh
#!/bin/sh
gksu cp conciergeserver /etc/init.d/conciergeserver
gksu chmod 755 /etc/init.d/conciergeserver
gksu update-rc.d conciergeserver defaults
gksu service conciergeserver start
sleep 5
xdg-open https://localhost:8989
I don’t have gksu installed. Simple to fix.
I get you close … you can change the gksu to su … in the various scripts that are generated.
You need to do the update if you want upgrades to work.
[quote=“RichardTSchaefer, post:2, topic:198311”]I get you close … you can change the gksu to su … in the various scripts that are generated.
You need to do the update if you want upgrades to work.[/quote]
installing gksu was not an issue.
Everything was working without the update. It was awesome!!
Now that I see 2.019 is available, I’m dating it right now!
Thanks!
[quote=“gniknalu, post:3, topic:198311”]Everything was working without the update. It was awesome!!
Now that I see 2.019 is available, I’m dating it right now! :)[/quote]
Noticed my customization changes disappeared when I updated. No problem - I printed a paper that had the originals. Just thought I’d mention it in case someone else encounters it.
You can always save the .jsonenc file as a backup.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Then what? Will I need to diff the old with the new? (It should be something mentioned in the docs if that is the case.)
Thanks for responding.
