Complements and a suggestion for this highly appreciated plugin
The DataMine plugin is the best and most used plugin for my Vera 3 for analyzing my home and troubleshooting . There is a lot of progress in the evolution of this app. I surely want to give a big ‘thumbs up’ for your hard work!
Some humble suggestions from my side:
  • Is it possible to add a function to the Chart section to sum variables from different channels into one chart, similar to the dashboard function?
  • Is there anyone out there using this app, who made a sort of template which can import the data from the datamine plugin to Excel/Calc?
Keep on the good work! It’s highly appreciated!
Thanks - I’m glad people find it useful :slight_smile:
Do you mean this for graphing the watts in the same combination as the dashboard, or do you mean for combining other types of variables? I will likely add the ability to graph the combined energy totals.
Data export is something that I’ve had on my todo list for a while. I’ll see if I can add it in the reasonably near future.
Cheers
Chris
Do you mean this for graphing the watts in the same combination as the dashboard, or do you mean for combining other types of variables? I will likely add the ability to graph the combined energy totals.[/quote]
I like to have the possibility to select variables, like, for example the power consumption, to be shown cumulative. Something like the U5’s ‘Energy’ → ‘Usage’ but then shown as a graph. Also it would be nice to have the summed variables been subtracted from the overall total, like a total powerconsumption, with a rest variable been shown, like what you did in the Dashboard with the variable ‘Unaccounted’.
I hope you know what I mean. English is not my native language, you see… ;D
I think I understand. I do have plans for something along the lines of what you’re after, and I hope to get this into the system in the near future (assuming there’s not too many problems with the latest upgrade that changes the file structure) :wink: Once I release this, let me know what you think and if you have any further suggestions…
No problem - your English is fine - certainly better than any second language I can attempt to speak :smiley:
Cheers
Chris
Tnanx a lot!
I will look forward to the upcoming changes and, when needed, I will be back to provide some constructive criticism… :wink:
One of the things I have which is related is that I have some old switches which don’t have energy meters and a thermostat controller , which can’t have an energy meter since it does not have the load current running through it.
However both of these have a value called “User supplied wattage” If you could log the switch state SwitchPower>Status multiplied by the “UserSuppliedWattage” that would fix this
I’d guess a generalised calculation type logging would be able to handle this, I mention this as the UserSuppliedWattage is built in to Vera so you would be using that feature of Vera.
Finally , this is an awesomely good app, In my use of the ERGY application I found ERGY does not handle a WholeHouse meter , it just added that to all the other meters, Furthermore and much worse it does not handle a Linked Vera, My ERGY account only shows the main Vera’s wattages none of the linked vera’s wattages are present.
[quote=“rjwilson01”]One of the things I have which is related is that I have some old switches which don’t have energy meters and a thermostat controller , which can’t have an energy meter since it does not have the load current running through it.
I’d guess a generalised calculation type logging would be able to handle this, I mention this as the UserSuppliedWattage is built in to Vera so you would be using that feature of Vera.[/quote]
This was an activity someone else had asked for as well.
http://forum.micasaverde.com/index.php/topic,13300.msg99038.html#msg99038
