cd altsteon-code/
cd altsteon-daemon/
automake --add-missing
./configure
make
make install
At that point, the altsteon binaries are installed and executable.
When you execute on a separate system make sure to use the -r flag. I did not have to specify a port inside of vera, just the ip address of the raspberry pi.
I have a number of Pis around doing simple stuff and love them. Out of curiosity, what would be the advantage of running Altsteon on the Pi vs on the Vera?
I like the idea of a semi-self contained box (i.e. running Altsteon on the vera), but curious if there is a performance consequence and that’s why the Pi idea was being pursued.
I had some performance issues and felt like taking load off of the vera would be good. Since I had the raspberry already running, I thought it would be a good thing to utilize.
I’m getting the same error, but did not get it to compile on my ubuntu server.
I ran the commands you suggested, installing automake and ran:
./configure
make
I get a warning on automake about version differences, then a warning about depreciated functions. ./configure throws no errors, but there is nothing to make…
Any help would be appreciated.
Full console:
~/altsteon-code/altsteon-daemon$ automake --add-missing
configure.ac:6: error: version mismatch. This is Automake 1.14.1,
configure.ac:6: but the definition used by this AM_INIT_AUTOMAKE
configure.ac:6: comes from Automake 1.11.6. You should recreate
configure.ac:6: aclocal.m4 with aclocal and run automake again.
configure.ac:6: warning: The 'AM_PROG_MKDIR_P' macro is deprecated, and its use is discouraged.
configure.ac:6: You should use the Autoconf-provided 'AC_PROG_MKDIR_P' macro instead,
configure.ac:6: and use '$(MKDIR_P)' instead of '$(mkdir_p)'in your Makefile.am files.
~/altsteon-code/altsteon-daemon$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking for unistd.h... (cached) yes
checking for size_t... yes
checking for memset... yes
checking for socket... yes
checking for strdup... yes
checking for strstr... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/tests/Makefile
config.status: creating tools/Makefile
config.status: creating tools/cli/Makefile
config.status: executing depfiles commands
~/altsteon-code/altsteon-daemon$ make
make: *** No targets. Stop.
So do you use Vera to control the devices and scenes with Insteon products or is there a separate interface that you have to access on the Pi? I’m using that Vera Insteon on the Edge, but with only one USB port I wouldn’t mind off-loading it to a Pi, but wasn’t sure how to manage multiple controllers.
Not totally following your sentence, but I think you are saying that you are using Vera’s implementation of Insteon? If so, Altsteon has not worked for me on the Edge. If you have gotten it working, I’d like to know how, but in the meantime, I use a Vera Lite with UI5 and it talks to the Raspberry Pi. I use vera to control the devices from Altsteon.
cd altsteon-code/
cd altsteon-daemon/
./configure
make
make install
When you execute on a separate system make sure to use the -r flag. I did not have to specify a port inside of vera, just the ip address of the raspberry pi.[/quote]
Ok, this helped a lot. I had to run “make install” as su because it didn’t have permission to write to /usr/local/sbin.
Then you have to run “altsteon -r” to allow remote connections from the Vera, I spun my wheels on that for a few minutes too. (even though you pointed that out, I missed it)
I’m still on UI5 right now and it works fine with the PI. I have another Vera that I’m going to install UI7 on and see if it works.
