Comcast help
OK… just got my VL tonight… tried to hook it up, and it’s not connecting via the internet to MiOS. then I notice that I can’t even get to getvera.com any longer. I’ve been on that site on multiple PCs in my house all week… and today, no go. Talked to Comcast (my internet provider) and they swear they haven’t done anything, but I wonder if they are suddenly blocking the IP address? Every other website I use comes up fine. But this one won’t load the page, even though the tab renders the name correctly.
and I just got my unit today??? WTF? Is there something i’m doing?
Eh? maybe getvera.com is down. So what? Flimsy website any way.
Your Vera not connecting is potentially a real issue though and may mean an outage, which has apparently happened from time to time. It seems to work for me ATM so you might want to double check everything on your end to make sure your Vera can get on line. Can it get the time and so forth from the internet? Are there any other signs that your Vera isn’t internet savvy at this time?
Pardon me for being new… as I may be missing something, but this is what’s happening.
I talked to Vera support, can we could connect to it if connected directly to a PC and not my router.
When connected to the router, MiOS setup “sees” it, but when I actually try to connect to it, if fails… so I never get to the dashboard at all.
Updated the firmware in my router (ASUS), same problem.
Talked to Comcast… they say that “maybe” they’ve blocked the IP. S-F, i’m guessing you are not on Comcast???
Unhooked everything… rebooted router, PCs, etc… still can’t even get to getvera.com… so I also can’t get to support, etc. Micasaverde.com seems to work.
I’ve also tried this on Win 8.1 and Win 7 PCs… same issue. Tab in IE resolves, but page won’t render.
Sounds like a firewall problem in the router. You might need to open up some ports or allow the VL access to the internet from inside the routers command panel.
Yeah I’m on Comcast. Just find the LAN IP address of your Vera and type it in your browser to configure it.
