I just spent a ton to have all the ductwork in my HVAC system reworked. This summer I want to collect the temp data from the sensors in the rooms. Rather than looking at all of them one at a time, I thought about automation. Would it be possible to create code that will periodically grab the temps and send them via telegram?
Anything else would just be an emergency solution for me. A notification mesh bot would also be conceivable, which packs the data into a message every x minutes (but there would have to be placeholders for this, which do not exist). But then who would want to type out the data from the news?
Can you interrogate these sensors from Ezlo already? If so then it would seem possible to create a meshbot to run periodically to go poll all these sensors and forward the results via some notification method.
I did something similar several years ago to diagnose a problem in my HVAC system. I used a RaspberryPi with a flash card and would read temps from four DS18b20 sensors in the return and supply plenums. Each read cycle was a new record in the flash file and later on I could read the file into excel (csv format) and then analyze the data. I had to write my own python program but it was pretty basic. There are libraries for things like DS18b20 sensors so you don;t have to get too deep in the weeds.
I was thinking about running something every couple hours and just grabbing current temps and sending them. I donât want to collect them past just sending them. Iâm looking for something similar since I have no idea where to even start. I can rework something similar existing. (I hope)
Not sure if this can be done yet in Meshbot rules?
In MSR you can, in a rules action using âNotifyâ in the Message field you can not only add regular text, you can also add the value of a variable(s) into that message text also.
For example âbattery_low_namesâ being the names of my devices that have low batteries, and the current battery level value, as an example from one of my MSR rules that sends messages to Telegram.
As of now we dont have the ability to directly send the data out using variables or in HTTP requests.
But we are already working on the development of it. So shortly we will release this feature.
For a temporary solution, a Lua script or plugin can be created and that would subscribe to the hub broadcasts, filter sensors per device name/id, and then send it out to a 3rd party URL
I will have a look at it and see if we can have a simple version for this.
What about the data logging function? Is there anything planned? Power consumption, temperature profiles, switching processes and the graphical representation of this data are for me and certainly for many others one of the basic functions of a smart home.
Hi, @Odysee , @cw-kid
We already have the basic infrastructure of the data logging and visualization , so we will be building on top of that to give you access to data through cloud first and view it through charting capabilities on the dashboard. This should not be more than couple of weeks at latest.
In parallel we will build APIs on the hub to extract and export the data from sensors to any endpoint you like. I canât give you a timeframe for the second but we will try to do it asap.
