im setting up a wall switch and keep getting code 4? whats that mean?
How about some more info? Which vera? Which firmware? Which switch? Where do you see the code, in the UI? In the log? Do you see it when trying to pair, or when you’re trying to send a command, or when your trying to poll the device?
