Cloud Meshbots - Notifications not working, Triggers not working
I created two Cloud Meshbot to control my Honeywell Tstat; AC OFF and AC ON
Trigger: Set Lanai door sensor that when state is 0 or 1 (presumed binary but also tried text closed / open)
Action: Set Honeywell Tstat mode to OFF
Action: Notification - send push and email.
From phone setting up Meshbot, Notification is not saved.
From Computer editing Meshbot, Notification is saved.
Results:
  1. Trigger does not initiate Action. What am I missing? Device is connected to Controller.
  2. Notifications do not go out at all regardless of save state.
  3. If I manually run the Meshbot(s), Tstat does change mode between ON and OFF.
  4. Logs show Trigger (no explanation, presume notification event) and the finishes with Trigger (explanation says Scene … Failed
I have tried setting of a test meshbot for Geo and I never get notifications either.
Hello @lmacvey,
I apologize for the delayed response.
I’ve created a support ticket so we can review your setup in more detail privately. Once we have more information, I’ll share any relevant findings here as well.
In the meantime, could you please check your inbox and enable remote access on your controller?
Thank you!
