I was able to get all the room images working when local, but would like to show them when I login via remote as well. Does anyone know how to get this working via remote session?
Kyle
Kyle
[quote=“kyle.dawson, post:1, topic:200027”]I was able to get all the room images working when local, but would like to show them when I login via remote as well. Does anyone know how to get this working via remote session?
Kyle[/quote]
assuming you put your room picture file on a place accessible from the internet ( because in remote access you are on internet ), then they are accessible
for instance: i have put a file called R_0-1.jpg on the github ALTUI repo, the file is therefore downloadable with a url like https://raw.githubusercontent.com/amg0/ALTUI/master/Photos/R_0-1.jpg
so take the base path of it :
and store that in the ALTUI device variable called “ImagePath” , that should do the trick for both remote access and local access. cf screen shots
Thanks, but I just played around and found a way to use same location for both local and remote. Plus my images are still private.
In Vera, under the ALTUI and settings, I updated the variable.
MyHome Image Path = …/
This makes sure the image files are up one directory. Since local is the root, it works. With remote, the site is via a different sub directory, port_3480. WIth new …/ this forces the images to look up one dir, that is root of vera from remote.
[quote=“kyle.dawson, post:3, topic:200027”]Thanks, but I just played around and found a way to use same location for both local and remote. Plus my images are still private.
This makes sure the image files are up one directory. Since local is the root, it works. With remote, the site is via a different sub directory, port_3480. WIth new …/ this forces the images to look up one dir, that is root of vera from remote.[/quote]
very good. so where do you put the images on vera ? directly in /www ?
Yes, I left them in the original location /www
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
