paros
February 1, 2017, 9:41am
1
Can someone give advice how I should understand the values from Eventwatcher (what is normal/not normal)?
For example, I have a Vera Plus and have the following values:
Vera Memory
Red line: 150MB
Blue line: 195
EventWatcher Memory
0.41MB
Vera CPU
30%
akbooer
February 1, 2017, 10:01am
2
[ul][li]red - free memory[/li]
[li]blue -available memory[/li]
[li]EventWatcher memory - the amount being used by this app only[/li][/ul]
In Unix terms, available = free + cached, so you have lots of elbow room.
The time to worry is when free suddenly dips low.
My Veras (Lite and Edge) typically run at 20% CPU, but I’m not using any heavy plugins like PLEG.
paros
February 1, 2017, 10:06am
3
Would it be a good idea to write a short explanation on the reports?
akbooer
February 1, 2017, 10:22am
4
The blue area in the memory plot shows ‘cached’ memory, the red is ‘free’, the total being the ‘available’ memory. If the free memory falls towards zero then the Luup process is liable to restart itself.
…agreed that’s not the same as on the report itself.
