I thought that checking “Show OS Statistics” in options would display CPU load in the footer.
Once I did that I get “Unregistered version for faa409fc-ac74-4c47-9415-556951884fc4.()”
In the footer I now see
first couple of important questions
a) do you see any error in the javascript console log of the browser
b) are you on openLuup ? if you tried on VERA UI7 first ?
c) what is the result of the command line “top -n 1” on your system ?
ALTUI uses the command “top -n 1” on VERA Linux splited by “\n” then take the first 3 lines. various variant of Linux may result in different results here.
I had the problem with the “unregistered” message on both chrome on win10 and on my android device.
Right now AltUI seems to recognize me again. I didn’t change anything till now.
Problem with the OS statistics remain, so here are the answers to your questions:
a) no errors related to openluup / altui as far as I can tell
b) i am on openluup. I don’t run UI7, still on UI5.
c) When I run this in a terminal on openluup I get
