I have 11 door/windos sensors. I like to make a RGB lamp turn red if one or more sensors is open and if all sensors are closed the lamp shall be turnd off… The red RGB is not so important just a lamp on/off is great!
One sensor → lamp is easy but more then one…? i can not fix it ![]()
Optional is to make the RGB lamp flash green if any of the battery powerd devices are on low power…?
Is it possible? Thanks!
