My kids found the passkey on backside of the unit and have given it to their friends. I need to change it, can anyone help?
Setup > Net & WiFi
Thank you for the reply, I have been there and when I click on manual configuration nothing happens. From what I understand, options should populate the screen at the bottom of the page that will allow me to change the SSID and passkey. Am I doing something wrong?
I would assume your on UI6 1.6.xxx? If so, this appears to be a bug and you’ll need to contact mcv support.
- Garrett
you are correct, thank you for the reply
