I’ve recently added a new variable to my Heatmiser thermostat plug-in following a user request. Everything works as expected apart from one thing. When I select the Heatmiser device on the scene ‘Advanced’ tab the new variable appears in the drop-down and when I pick it a line appears under ‘Delay: Immediate’ as expected, but there’s no entry field on the right - hence I can’t change the variable when a scene is triggered. The data entry on the device ‘Control’ tab works perfectly.
The variable has my own service ID because there’s no suitable alternative in the standard thermostat variables, and obviously I’m missing something in one of my plug-in files. What statement is required to specify that a data entry is expected on the scene ‘Advanced’ tab?
Can anyone point me to a solution please? I’ve tried several search terms on the forum, without success.
Thanks in advance!
