Changing the DSC icon
Hi
This is more an OCD thing, plus the last thing I want to do is break anything to do with my Vera → DSC set up, but I was wondering has anyone changed the icon on the DSC plug-in ?
I?m running it on UI5, and one of the tiles just has a stock icon - where as I do have a 42x42 compatible version (attached)…
Well I’m on UI7 but I’ve added an icon for a device. I don’t think you can upload the file using the Vera web interface. You need to copy the file using WinSCP or something similar. Copy the file to /www/cmh/skins/default/img/devices/device_states/ You’ll then need to modify the JSON file for the device - or else rename the file to match what’s in the JSON file.
