We are experiencing a problem with running scenes from Automation HD software. Specifically, the Active/Inactive state shown for each scene is not consistent with Active/Inactive status that we see on Vera app/web interface.
If we manually activate a scene on Vera interface, it will work in Automation HD, and the Run button also performs the scenario manually. However, if the scenario is Inactive in Vera interface, the Run button doesn’t work in Automation HD and there isn’t any option to activate it directly (without Vera UI).
I will appreciate if you share any similar experience, or perhaps an idea to fix this problem
Thank you very much.
Mona
