I use vera1 as my router.
I have a windows home server (WHS) also on my network that runs a little website, allows RDP, and handles my DDNS.
I HAD the vera all setup to forward the 4 ports that the WHS needs and then to drop all other ports. It was working fine.
well today I went to remote in from my office and I couldn’t connect. (ironically i was going to try and open port 22 so i could use ssh to set up a tunnel to my vera for my Droid phone) Figured just maybe there was some lag in the DDNS updating so didn’t think much of it.
But when I got home I see the ports just aren’t open. I hardly remote in or use the website- so who knows how long it’s been off. (I think i originally set it ip in .979 but now I’m .994- so might have got fubared when i changed. I know i had problems with it forgeting static dhcp settings at the time- so maybe i just never noticed it.
Anyway- originally i set all the firewall rules in the “advanced configuration” item that opens a new window to fiddle with the open wrt settings. So I looked in there and all my firewall rules went bye bye. So I set them all back up and i still can’t get the ports to open. I tried opening port 22 in there to no avail either (using the shields up port scanner at grc.com shows them as ‘closed’)
So then I noticed that in the vera ui itself I can pick a firewall setting- and on of the options from the dropdown is ‘firewall custom”- honestly I don’t think I touched that originally I thought I just fiddled in the open wrt page. But now I guess I need to set that. Trouble is- no matter what I do I can’t get the setting to change to custom. It’s stuck on firewall active. I tried “save and apply from the scrolling part of the window with the network settings. I tried the save button up top on the left as it goes red when I make changes. I tried both of them in different orders. I tried putting rules in the open wrt page, I tried deleting them. I rebooted umpteen times. Still no matter what I’m beat.
Anyone have any idesas? I’ll wait for the next version to drop and try again and if it doesn’t work I’ll open a ticket. But maybe I’m just doing something wrong that I’m not seeing?
-mike
PS- once I get that setting to stick- will something pop up in vera’s ui to set the rules- or do I still go to the openwrt page?
