I have a GE Dimmer switch (#45606) installed i the kitchen. When I turn it on it slowly lights up to 100%, like they all do out of the box. In the kitchen however I am looking for a more “instant on” type of effect. When I walk into the kitchen it’s because I need someone so I want to be able to have it get to 100% quickly, near instant but with a very very slight fade on. Reading the manual (http://www.smarthome.com/manuals/59490.pdf) I see that I can change the interval steps, etc. but I guess I can’t figure out where to input them in the device settings or what to change.
According to the manual, there is no way to set it to a certain level when you turn it on manually, but you could setup a scene with an event (switch on) and set the desired level on the ‘Commands’ tab of your scene. Not the perfect solution, but might work.
