Changed ISP
Folks, I upgraded www access due to better speed and bandwidth and my CAMs no longer show in VERA. I’ve searched forums and wiki’s . . . but have yet found a solution, so I thought I’d ask for help.
For a couple years the cameras (vistacams) worked well and were fully functional via the vera UI (and apps). I’ve established communication with micasa verde and see all functions of the zwave but the CAMs don’t show the feed, even though they show through the IP addresses that my router displays (to include MAC addresses confirmed).
So any advice (step-by-step) is appreciated for what I need to do since I have new ISP and router, but no other change to the zwave.
I have changed ip address in the UI5 after re-setting up wireless pword in the vistacam setup
[quote=“DECOOPER, post:1, topic:184901”]Folks, I upgraded www access due to better speed and bandwidth and my CAMs no longer show in VERA. I’ve searched forums and wiki’s . . . but have yet found a solution, so I thought I’d ask for help.
I have changed ip address in the UI5 after re-setting up wireless pword in the vistacam setup[/quote]
How about port numbers. Are they all good? Shouldn’t be much different but maybe an IP address when you change providers. Is the modem a router also? Routers could be blocking (firewall) connections. Did you change router or only modem?
Ports and IP addresses were confirmed with new router. I was under the impression that I could just change w/i the UI, BUT it appears thats not the case. I evidently have to reset up each camera. One working now by completely removing from vera, removed APP and started anew. I hate that I have to reset up notifications, triggers etc… but it is what it is.
Thx for the reply ~
