I have several Vera devices running and I’m trying to provide a means to SSH in to each. My basically stupid router, an AT&T uVerse NVG589, complains if I try to set up a NAT for more than one of them i.e.
External Address External Port Internal Address Internal Port
xxx.xxx.xxx.xxx 1022 192.168.1.101 22
xxx.xxx.xxx.xxx 2022 192.168.1.102 22
xxx.xxx.xxx.xxx 3022 192.168.1.103 22
The router will accept the first mapping but rejects any more mapped to the same port even though they are different target devices.
So it looks like the only way around it is to actually change the target device SSH port if possible. I’ve looked in the various configuration settings but it appears the SSH port is not definable.
Thanks, I wasn’t crazy about the idea but I had run out of alternatives. My router used to support this but somewhere in the past two-three weeks they did an update and now its “smarter” and won’t allow it.
Just buy a Raspberry PI 3 and hook that up to your network. Easy peasy to set up and run even for a Linux newbie. There’s your ‘unix’ server for less than $50 (including case, keyboard, PSU, SD card et al)
As an added bonus you can run Pi-Hole (https://pi-hole.net/) on it and block all those annoying ad banners right at the edge of your network. Even some in the various apps. Once you set it up it’s basically ‘fire and forget’.
I believe there is a SSH server service for Windows as well if you have one of those running and feel more comfortable with that OS. If it wasn’t for Blue Iris, I could have run everything else I needed on my existing Unix server. ZoneMinder would be an option, but I’d have to build a new server with a different Unix flavor for that so right now, Blue Iris it is for camera support. I recently saw the HikVision software in action on a setup with 350 camera’s. Oh boy, me likee but to expensive for home use.
Do some google searches on dropbear with multiple ports. Others have asked not related to Vera or home automation. Seems it can be done with 2 config files but as it was pointed out your changes would probably be gone after a firmware upgrade.
