Just found a useful page that is the change logs for both the iOS and Android Mios apps. (Just the last two versions it seems)
Would think you’d need to be on either the Apple Test Flight or Android App Tester programs to get the very latest releases though. Not sure how often they update the regular app store versions?
EDIT: 1.6 (21) is the version in the public Apple App store, I just checked it. And version 1.114.0.561 is in the Google Play store also. I thought these were test versions but they are in fact public versions recently released.
July 17, 2024
MiOS iOS App v1.6.21
New Features
- Native Dashboard
- Support for EzloPi devices
- Pin configuration support for EzloPi devices
- Geofencing
Full changelog
The MIOS app now features a native dashboard as the default option for a seamless experience.
Introducing support for EzloPi devices with seamless pairing and intuitive UI configuration
- Implemented provisioning, added EzloPi option in controllers type, and improved UI for Instructions, Detected devices, Configure WiFi, and Success screens.
Fixes
- App no longer crashes when trying to configure a device not connected via Bluetooth.
- My Controllers now accurately displays available options for EzloPi devices.
- Enabled operation of EzloPi devices from Dashboard or ‘Devices’ menu.
- Corrected issue where Generic EzloPi device with configured pins didn’t appear in the Devices list.
Introducing pin configuration for EzloPi devices in the iOS mobile app
Implemented features
- View and manage existing EzloPi device configurations.
- Correctly display configured EzloPi devices on dashboard and devices list.
- Configure EzloPi devices with various types: Digital Input, Analog Input, PWM, UART, One Wire, I2C, and Other.
- Choose to keep existing device ID or create a new one and enter Wi-Fi credentials for the network.
- Select chip type for EzloPi devices.
- View a list of existing configurations.
- View configuration type options.
Introducing Geofencing on iOS mobile app
- List Screen for geofences.
- Map screen for visualizing geofence locations.
- Settings popup for configuring geofence settings.
- Add/Edit screen for creating and editing geofence entries.
- Support for geofence in scenes, allowing for location-based automation.
- Scenes block implementation for scene-based automation.
- Active device logic implementation.
- Registered geofences to be monitored by the phone, enabling location-aware features.
Fixes
- Fixed error on Meshbot activation event.
- Corrected issue with location limit not being set.
- Arrow icon will now be removed when deleting geofences for a cleaner user experience.
- Token no longer displayed when editing locations.
- Geofences can now be used as a trigger for meshbots as expected.
- An issue with the LocationManager was resolved, preventing errors and improving performance
General fixes
- Resolved issue where users couldn’t add Smart Start devices by entering DSK codes manually.
- Snapshots are now correctly displayed under Cameras/Doorbells > History in the MIOS app.
- A manual input field has been added to set the Z-Wave Dimmer Duration setting value via the mobile app.
- Fixed issue showing a token in the Scene controller ButtonControls screen.
- Select connection security screens will now only appear once, without duplication.
- Users can now save their time zone settings on Water Valve hubs without issues.
- Camera previews are now showing correctly on the Devices/Cameras page.
- Corrected an issue where a dialog was incorrectly displayed on the login screen of the app after installation.
- The onboarding loop has been fixed to prevent unnecessary redirects during setup.
- Fixed condition causing a crash while opening the Device Pairing Wizard (DPW).
- Device icons are now displaying the correct status consistently.
- The capabilities and state of Scene controller buttons are now displayed correctly.
- Fixed a corner case where a newly paired device would not be visible on the UI.
- Manufacturer specific thermostat modes are now displayed on the UI as expected.
- Heat sensor icons are once again visible in the MIOS app.
- Fixed a condition causing the Include/Exclude buttons to not be visible on the Devices Screen randomly.
- Users can now select a security level during device inclusion.
- Siri Shortcuts functionality has been fixed and will no longer stop working after 24 hours.
July 12, 2024
MiOS Android App v1.114.0.561
New features
- We’ve improved the account cancellation process in our MiOS App, making it easier for users to manage their accounts.
- The Device screen now correctly displays measured values from the MCO Home A8 9in1 sensors.
Fixes
- Users can now create Pincodes without encountering issues.
- We’ve added support for displaying measured values from CO2 Level Sensor, Loudness Sensor, Particulate Matter 2.5 Sensor, Smoke Density Sensor, and Volatile Organic Compound Level Sensor.
- The “More” section of the app is now displayed correctly even if a user doesn’t have controllers, making the experience more consistent.
- Delete icon was removed from the Account Administrator - User edit screen to simplify the interface. The user can still use the “Delete My Account” item in the menu.
- Users can now set PIN codes for doorlocks using the MiOS app without encountering issues.
- Selecting and unselecting check marks on Meshbot actions is now functioning as expected.
- Recordings > History menu no longer displays duplicate entries, providing a more accurate experience.
