Change from Fahrenheit to Celsius
Hello
Just started using Veralite today. Connected Everspring ST814 Temperature/Humidity sensor,but even if the sensor is showing Celsius, Veralite shows Fahrenheit. Location changed to Norway in setup
Anyone has a clue?
Thor
Hey
I’m new to Vera too but check under the device configuration:
Click on the spanner icon above the sensor device - select the advanced tab - scroll down and you’ll see a section called ‘Variables’. See if there is a reference to Celsius/Fahrenheit there, if there’s a 1 in the box next to it, try changing it to a 0 or vice-versa.
Let me know if that helps?
Latz
Thanks for helping me out
Attachment shows the different choices, but Fahrenheit or Celsius is not an option.
Open to more suggestions
Thor
Did you also change the “Temperature Format” field in Setup > Location?
Excellent, this made the trik.
Thanks for the help
Thor
